Cam choice is the driving factor.
As cam duration is increased, the intake valve closes
further and further past bottom dead center.
This reduces the Dynamic Effective Compression Ratio, kills power.
Static CR is a pure ideal figure, total BDC volume / Total TDC Volume.
Am running an AMC 343 block with 360 crank offset .010
dished top 26cc 360 cast pistons, -.007 deck clr (above deck)
'70 heads milled .060 for 47cc's, Torker, Holley 750 DP.
Has 10.2:1 CR Static, Elgin E-1041-P cam, spec'd 5200rpm max
.488/.488 - 218/218 - 284/284
With the 10.2:1 Static CR, can run 93 pump gas all day long.
Dizzy is 15 initial, 24 mech adv, 39 total, all in by 2800 rpm.
No ping or detonation.
Makes 407 HP gross IF 25% drivetrain loss is used.
Makes 381 HP gross IF 20% drivetrain loss is used.
Not in a Jeep, in an AMX, Auto, 3k stall, 3.73 gears.
Stall and gears are almost too much for this "small" cam.
Car with driver is 3250 lbs, runs 12.6 at 107 mph.
Above HP figures derived from the 3250 lbs and 107 mph.
To make the engine thump and make power and torque,
need to build for 8.5:1 DYNAMIC Effective CR for pump gas.
Pick the cam first, then can use the Dynamic CR Calculator
on the Keith Black Silv-O-Lite web site to determine what Static CR
will result in 8.5:1 Dynamic CR based on the cam's Intake Valve Closing Angle.
Think about it, how hard the pistons push on the crank after the fire is lit
is where all the power and torque comes from and CR directly effects how powerful the bang is.
Trust me :wink:
Hopefully, others here will confirm what's been said. :-|
Link to recent burnout video, and actually a pretty weak one at that,
compared to what it could do, faith in cameraman was limited
that it was actually getting recorded or not, so was reluctant
to really realy burn it down and masacare the tires.
Did just that on the first attempt, and it didn't get recorded 111!!!
Marks from first attempt are visible in the driveback clip
and going the other way in the final burnout clip.
http://www.youtube.com/watch?v=iYtxM2d5tfw
