mkzmomo
is there different eccentric model for the fuel pump, amc 360, ... mine is starting to get grooved in? might have find one but it's not the same as the old one but check the numbers with the dealer and it's supposed the be the same
BREK
They should all be the same from any amc v8. Factory part# j3218314. Chrysler has discontinued this part.
mkzmomo
thanks BREK for the info,
the one I've got is not good ! i'll be looking around then
AMX69PHATTY
Have seen 2 designs, they're interchangeable afaik,
old one is 2 piece, a "tri-lobed" part that's keyed to the cam and a seperate "cup" that rides on it,
other one is a solid single piece eccentric with a cutout on the front.
