mkzmomo
Well I ran in a problem when It was time to put the crank on. The crank would not sit in the thrust bearing, checked if I got the right bearing they are clevite 77 and the size is good .10
took the crank off and tried the upper and lower part of the bearing by hand directly on the crank and nop they are to wide ?? they wont fit in between.. what can I do?
looks like I got the wrong one but I double checked the numbers on clevite website :-|
get new bearings
try a different brand or see what the specs are on the journal width
You are trying them in the center journal (#3), not the rear like a Chevy, right?
mkzmomo
they all fit good except for the rear one, the bearing is good on the bloc but not in the crank groove
i will cheak with my engine shop on monday
the thrust bearing doesnt go in the rear main. It goes in #3 or the center one. they are different than the chevy.
mkzmomo
ohhhhh #-o that's why !! chevy habbits oops
thanks for the cue guys !
I will take care of that in the morning :oops:
