I'm in the process of rebuilding an 85 360 for propane.
EDIT: My current build-
1973 Jeep CJ5 on CJ7 chassis
360 (1978) bone stock with the following upgrades:
- Summit K8600 Cam & Lifters
- Motorcraft Duraspark II Dizzy w/ MSD "BIG" cap
- MSD 6AL CDI
- MSD Helicore Wires
- Edelbrock Performer Intake (#2131) non-EGR
- Impco 425 Mixer & "E" Vaporizer (Propane)
- Added 4/28/09 - Valve Job & 0.038" Head Shave
(Running late heads w/ stamped steel rockers)
BW T15 man trans
D20 T-case w/ 3.15:1 Kit
(soon to be TH400 w/ Atlas 4-Speed)
5.86:1 Axle Ratio w/ 42" Iroks
Excerpt by Franz Hofmann-
Propane has a theoretical CCR somewhere around 12.5:1, and again, this depends on the purity of the fuel, usually between 90 and 95% propane, the balance being propylene, ethane, butanes, and other minor fractions. Of all these fuels, propane has the longest burn duration, and the highest octane, and the highest resistance to ignition. The other fuels tend to diminish the combustion quality of propane. Propane can and will work effective with higher compression ratios, but at some point, the added heat during compression, the detonation and risk of pre-ignition, and reduced power gains eliminate any possible gains from the increased compression ratio.
I have read elsewhere that Propane is happy at 10.5:1 to 11:1 Static CR, so – how to get there?
Forged pistons – 4.125 Bore comp ht 1.601 21.66cc inv dome
advertised 9.5:1 with 57.92cc head.
Summit K8600 Cam
1.6:1 Bridged Rockers
2.025/1.68 Late 360 Heads w/ 57.92 chambers
Factory Crank & Rods
Impco 425 Mixer
I calculate 9.21:1 Static CR with the following calcs:
4.125 bore
3.440 stroke
5.875 rod
4.25 x 0.046 fel pro gasket
9.195 deck ht
0.000 deck clearance
1.5 cc Top Piston to Top Ring
57.92 cc chamber
21.66cc Inv. Dome
Assuming a 0.060 mill on the heads for 48.32cc I come up with the following:
http://www.diamondracing.net/cocalc.htm
4.125 Bore
3.440 Stroke
5.875 Rod
4.250 x 0.046 Fel Pro Gasket
9.195 Deck Ht
-0.001 Deck Clearance
48.32cc Chamber
21.66cc Inv. Dome
10.19:1 Static CR
9.05 Dynamic CR
I am real close to my target of 10.5:1 Is there anything I overlooked to get another 0.5:1 CR bump?
Are my number correct? Or am I better off getting new pistons?
Should I upgrade to forged rods on an engine that won't see much of 5500 RPM?
