happyhoppy
I've searched and searched for a concrete list of what the Go Pac option was. So far (from cars listed) I found that it would be a Tach, 140 mph speedometer, posi rear end, racing stripes and front power disk brakes. I just purchased a 1968 AMx and it has all of these - is there more? Appreciate a link that would get me any info. Thanks.
AMX69PHATTY
1968 "AMX Story" Sales Brochure Optional Equipment:
Performance "Go" Packages:
Available with "AMX 390" CID 315 HP engine* or
343 CID 280 HP engine*, both with 4-barrel carburetor.
"Go" packages include:
- Engine,
- Power front disc brakes*,
- Special-duty handling package*
- Twin-Grip rear axle differential*,
- Heavy-duty engine cooling system*,
- E70x14 Red-line wide profile fiberglass belted tires*,
- Over-the-top Racing Stripe.
*Also available as a seperate option.
Automatic transmission.
Adjust-O-Tilt steering wheel.
Quick-ratio manual steering.
Power steering.
Power brakes.
Power front disc brakes.
Twin-Grip rear axle differential.
Special-duty handling package:
- Higher rate front and rear springs,
- 1-3/16" piston dia heavy-duty front & rear shocks.
All-Season air conditioning.
- includes 70-amp battery,
- 40-amp alternator, and
- heavy-duty engine cooling
- Heavy-duty radiator,
- Power-flex fan and shroud.
- (for cars less air conditioning)
Heavy-duty 70-amp battery and 40-amp alternator
Visibility Group:
- Remote-control left side mirror,
- Visor vanity mirror,
- Electric windshield wipers and washer.
Light Group:
- Trunk light,
- Glove box light,
- Parking brake warning light,
- Headlights on warning buzzer.
Dealer accessory "Rally-Pak"; engine gauges
- (oil pressure and ammeter) and clock
- (not available with air conditioning).
Solex glass, all or windshield only.
Chrome steel "Mag" Wheels (6" rim width).
Turbo-cast wheel covers.
Wire wheel covers.
AM or AM/FM push button radios.
8-track stereo tape player with manual
AM radio and two rear speakers.
Headrests, right and left.
Bumper guards, rear.
Engine block heater.
Undercoating.
1968 "AMX Story" Sales Brochure Standard Equipment:
290 V8 4-barrel with Dual Exhaust.
All-synchromesh 4-on-the-floor manual transmission.
Tachometer, 0-8000 RPM.
E70x14 wide profile fiberglass belted black sidewall tires.
Direct-action, independent coil-spring front suspension with
Heavy-duty springs and shock absorbers.
Heavy-duty front swaybar.
Rear suspension with traction bars and
Heavy-duty shock absorbers and
Heavy-duty semi-elliptical leaf springs.
Shock absorbers, 1" piston diameter double acting.
Hypoid Gear differential.
Recirculating ball-screw steering gear.
Standard Steering Gear, 24.1:1 ratio, 5.1 turns lock to lock.
Quick-Ratio Steering Gear, 19.3:1 ratio, 4.0 turns lock to lock, optional.
Power Steering Gear, 18.1:1 ratio, 3.8 turns lock to lock, optional.
Turning diameter of 33.5 ft.
Brake Diameter: 10", Lining Area: 167.5 square inches.
Fuel filters in tank and pump.
All-Season engine coolant.
Anti-smog positive crankcase vent.
"Engine-Mod" exhaust emission control system with automatic transmission.
"Air-Guard" exhaust emission control system with 4-speed manual transmission.
1969 AMX Sales Brochure Optional Equipment:
- 343 4V or 390 4V Engine
- Red-line Ployglass tires and 6 inch rim wheels
Adjust-O-Tilt steering wheel (not with manual column shift)
Power steering (recommended with air conditioning)
Power brakes
Power front disc brakes (V-8's only)
All-Season air conditioning:
- 55-amp alternator, and
- (standard with air conditioning)
Heavy-duty 70-amp battery & 55-amp alternator
Command Air Ventilation with 55-amp alternator
Visibility Group:
- Clock
Light Group:
- Trunk light
- Glove box light
Console with floor automatic transmission
Armrest and center cushion (not available with console)
Solex glass, windshield only
Solex glass, all windows (recommended with air conditioning)
Rally Stripe (for AMX available in Go Package only)
Special application of American Motors colors
Leather Seats
Styled steel wheels
Wire wheel covers
AM push button radio
AM-FM push button radio
Bumper guards, rear only
Engine block heater
Undercoating
1969 AMX Sales Brochure Standard Equipment:
Tachometer & 140 MPH Speedometer
All vinyl seat upholstery
Reclining bucket seats
Sports steering wheel
Wheel disc hubcaps
Airless Spare
V8 Handling package:
- heavy-duty sway bar
- heavy-duty springs
- heavy-duty shocks
Heavy-duty cooling package:
- Radiator
- Power-Flex fan
- Fan shroud
end of document
