mrtazwrench
We left the kids next door at My dad's to go to the polls, and I had some recycling to go down town also 8 miles round trip, well we made it almost 4 miles coasting down hill to a stop sign, backfired a coupple times, shot out some flame, I pretty much figured right away it had munched a gear. :(: I confirmed that after my nephew came with my other J20 to drag us home, pulled the dizzy, the gear on the dizzy is toast, looked as if the cam gear may be OK. I may slam in a spare dizzy to drive it the rest of the way in the shop. :roll:
Now what I have done to this motor, it has 71,200 orig. miles on it now, I had the timing cover off for a leak, found slack in the timing chain, replaced it with the Edelbrock full roller, and put in a midplate, still had the stock cam, and stock dizzy gears. Since I put it back together oil pressure has been good, not high or low, only odd thing is after the first few days it had a little tick, sounded like lifter, had oil in it with break-in lube in it yet, changed it and it was nice and quiet, the last coupple times I drove it before this I thought I could hear a dull tick but not all the time, it has 1-2K on it since reassembly.
I will be going through all the dizzy gear tech, but looking for input on what has been done to this motor. :t:
AMX69PHATTY
Wonder if the dizzy oiling features / passages in the Timing set are properly oiling the dizzy gears ?
Put the tip of a felt marker in the oiling hole in the cam and install the large timing gear again. I am willing to be it is because of the lack of lubrication from a oil slot that is off.
:idea:
mrtazwrench
jeepsr4ever wrotePut the tip of a felt marker in the oiling hole in the cam and install the large timing gear again. I am willing to be it is because of the lack of lubrication from a oil slot that is off.
:idea:
That will be the main thing I check, :t: after reading through the dizzy gear sticky, I see some other alignmet of oil passages I could have messed up. I've been wrenching for 20+ years, 15 or so for a living, but never had one of these in for a chain, I suspect issues with the timing set as long as I have been doing this I automatically look fo all the little clues that tell me how things had been assembled.
Another issue is that if the oil slot goes past the OD of the first bearing journal you will bleed off oil. This is an issue witht he newer Edelbrock timing gears for an AMC.
mrtazwrench
jeepsr4ever wroteAnother issue is that if the oil slot goes past the OD of the first bearing journal you will bleed off oil. This is an issue witht he newer Edelbrock timing gears for an AMC.
OK I can see opening up a slot that does not align, but what would I do about this? #-o I recall this gear having several slots, I figured it was to set different cam timing. :-|
mrtazwrench
Droped a spare dizzy in it and got it parked in the shop, I did not get it torn down yet, but the spare I put in came from a motor that was abused, I think had oiling problems and clattered the last time running, anyway that one was starting to wear the same way indicating I do indeed have an oiling issue with it.
msalaba
I had a 73 CJ5 w/ 304. I upgraded the points dizzy to the later Duraspark seup. I did not know at the time that you needed to keep the gears as a set. Of course the gears lunched after a mile. So, I changed the gear on the dizzy and go for another drive. Yup, lunched in a mile again.
After finding this site I learned that you replace as a set.
(Another great difference from chebby)
I changed the oil & oil filter after each failure. It was too late. The shavings got into the crank bearings. I noticed because my oil pressure went to 1psi @ idle and 20 psi @ 3500.
I pulled the pan off. It was full of shavings. Pulled the oil pump apart. It was scored and the pump housing was pretty well grooved.
My advise would be to make sure you clean teh shavings out of the pan, pickup and oil pump before running this engine again. I ended up replacing mine for a 360.
mrtazwrench
I had thoughts of pulling the pan as well, guess I'll be sure to now.
mrtazwrench
DING DING DNIG! We have a winner 🙁: sure enough the slot goes too far out on the rear surface next to the cam. #-o Now what do I do? contact edelbrock and ask what are you going to do about it? :roll:
ol' school power
mrtazwrench wroteNow what do I do? contact edelbrock and ask what are you going to do about it? :roll:
Oh hell yeah.
mrtazwrench
I think I'll tell them about the tick also and that I'm concerned that it caused My cam to go flat also, this did bleed off oil that goes to the cam also. :(:
ol' school power
Lube to the lifter base and lobes comes from the crank and rods as they're spinning. They're not directly pressure lubed.
If a lobe went flat, the chain wasn't the cause.
mrtazwrench
I had a slight clatter since reassembly at times, I was quick to blame the gear for that as well. :oops: Got a link to IFSJA someone found the issue before install, got no response from Edelbrock, thread has good pics.
http://www.ifsja.org/forums/vb/showthread.php?t=79741
My IFSJA post...
http://www.ifsja.org/forums/vb/showthread.php?p=835301&posted=1#post835301
RacerAMX
I rebuilt my 360 using the Edelbrock set. Has edelbrock responded to this issue yet?
I did use MC's oil pump gears, matched set of dizzy gears and one of his midplates for the external pickup . I get over 80psi on my cheapo Kragen oil pressure gauge when I prime it and oil flowing from the dizzy gear .
I won't chance starting it untill this issue is resolved.
mrtazwrench
RacerAMX wroteI rebuilt my 360 using the Edelbrock set. Has edelbrock responded to this issue yet?
I had an E-mail back after my initial contact, sent pic of the stock gear next to their gear, and a pic of one of their gears on a cam showing the slot is too long. I have had no response after the pics, and said I would send mor of the dammaged parts.
RacerAMX
I pulled the timing cover off today and removed the Edelbrock timing set.
My oil slot goes right to the edge of the camshaft, maybe 1/16 over, deffinetly not the 1/8 inch or more in the pictures that were posted. I used an old Crower Camshaft to check.
I think I will still have the slot welded a bit and then remachined flat to make sure its good to go.
mrtazwrench
RacerAMX wroteI pulled the timing cover off today and removed the Edelbrock timing set.
I sure would, it seems you don't want any oil to get out between the cam and gear.
mrtazwrench
We're nearing reassembly on this, went to Bulltear HQ today, verified the oil slot wa wrong, :idea: and that there was a DA error Me being the DA, I put the cam dizz gear on wrong, so the wear pattern was on the edge. :oops: I got all the parts now except a water pump. MC got it wiped in to shape in short order and fed me lunch! :sa: :t: =D> :mrgreen:
