jeepcj7304 wrotejust went out and looked pcv had a bolt in the end of the hose still from checking the carb. that im guessing caused the blow out right.
Good chance the bolt and the silicone caused it if you ran the silicone all the way across.
Silicone will let the end piece slip when the intake is bolted down.
