mkzmomo
I would like to have your advice on that
In my 360 build , I will go with roller rocker arms my engine shop will put 7/16 stud (1.6 rocker)... they said they can get me a nice set of self aligning rocker , is it worth it or guide plate is better ?
jeep cj5 set up
comp cam 268H cams K-kit
edelbrock perf intake
everything ported/polished
new pistons .30
bulltear pushrod oiling crank option
crank bearing oiling option
nickel timing cover
everything new....
FuzzFace2
I would like to know what rockers they would be using :-|
The HS have 2 different types and their self aligning roller rocker is a bolt on but dont think it is a 7/16 bolt?
Check out Harland Sharp site.
BTW what you have you can run stock rockers because the lift is not too big. Most if not all the time the slot in the stock rockers is not enough for large lift cams & high spring PSI.
Dave ----
mkzmomo
thanks fr the info FuzzFace2, I checked the harland Sharp site :) I liked what I saw :t:
