Wrench Man wroteHHMMM!???
I pulled the cover off of my '00 4.0 and it does have a thrust plate.
can these late blocks be retro'd back to the old style?, or do I need to find an earlier block for my stroker?, I've already got the cam and chain!
Yes they can. If you want any kind of performance cam, you have to use the older setup (Cam, timing set, cam bolt with pin and spring).
Check out www.jeepstrokers.com. Its all about stroking the 4.0.
