401 cam is a little ""bigger" as mentioned.
It has more lift & "dual pattern" duration, different exh & int,
where the 304/360 cam is a single pattern.
AMC Cams from 1973 TSM
304 / 360
14.75° .... BTDC Intake Opens
68.75° .... ABDC Intake Closes
263.50° ... Intake Duration
0.266" ..... Intake Lift - Cam
0.426" ..... Inatke Lift - Valve
56.75° .... BBDC Exhaust Opens
26.75° .... ATDC Exhaust Closes
263.50° ... Exhaust Duration
0.266" ..... Exhaust Lift - Cam
0.426" ..... Exhaust Lift - Valve
41.50° .... Valve Opening Overlap
401
25.57° .... BTDC Intake Opens
90.75° .... ABDC Intake Closes
296.32° ... Intake Duration
0.286" ..... Intake Lift - Cam
0.458" ..... Intake Lift - Valve
80.80° .... BBDC Exhaust Opens
42.75° .... ATDC Exhaust Closes
303.55° ... Exhaust Duration
0.286" ..... Exhaust Lift - Cam
0.458" ..... Exhaust Lift - Valve
68.32° .... Valve Opening Overlap
