JERSEYJOE wroteYes they can.
MC are you reading this?
this mid plate will not increase pressure ? it will only help prevent wear on the lower plate correct ? , and the releif spring is only a issue if i had to much pressure correct? but are you saying maybe in this breif time that it ran t, he rotating pump may have worn just enough on the plate that it has dropped me the 10 psi that i am short? i
