C.Boyer wroteThe plunger is exactly the same as when I was complaining I had too much oil pressure. So the spring side of the plunger is exactly flat?
Hmmm.
Mabye some new ones are, but the spare I have here (and the one in my engine at the moment) are hollow and the spring sits up in the plunger. Im sure this is to center the spring so it doesnt wear the softer aluminum bore of the housing.
Also, you mentioned the nipple is "super short" ?
It should be long, mine is .675" and again the plunger is hollow all the way up.
Im wondering if you have the wrong plunger. If yours is flat on the spring seat it is preloading the spring causing the excessive pressure you are seeing, and if the nipple is too short it will block flow.
If that spring is preloaded that far, and your oil pressure is that high, you run a really high risk of wiping the dizzy gears out. Be very careful until you figure this out.
You are in SoCal ?
If you are in the L.A. area I have a plunger you can have to get yourself going.
k.
