Thanks all for your suggestions and advice.
I'm finally getting this thing figured out. :!:
The primary throttle plates were open too far and I was into the transition circuit. I had over .040 of the slot showing and there only should be around .020.
To fix it I closed the primarys down to just cracked and adjusted the secondary plates to bring the idle back up.
There is a small set screw on the right side base of the carb. You get to it from underneath. Depending on your intake you may have to remove the carb to access it. I lucked out and didn't. This adjusts the idle stop of the secondarys.
I was then able to actually adjust the idle screws. It runs much smoother now. Plus my cruising vacuum went way up as well!!
Now as soon as my new brake booster arrives this thing will be idling smoothly!! Everytime I step on the brakes the idle goes up. 🙁:
Ps.. anyone looking for hard to find brake booster for the older CJ7s. These guys have them http://www.priorreman.com/ . $100 + 50 core..
