Complete setup including several different billet aluminum bracket options to mount the pump with or without alternator and accessories.
Choice of pulleys for mounting pump with or without accessories.
Drive mandrel options to fit either a 3 bolt, 4 bolt or chevy bolt pattern harmonic balancer.
Oil pan options with swivel or static pickup.
Prescreen suction side filter to plumb inbetween the pickup and the pump.
Pressure side inline oil filter to filter oil before sending it into the block.
Complete AN hoses and fittings.
Of course a quality external belt drive oil pump. Pressure adjustable.
Clutch setup option for the oil pump so that you can prelube your engine by spinning the pump with a drill or 1/2" air ratchet without taking the belt off.
All for the cheapest price possible 🙂
Wouldn't this be the optimum setup for wet sump AMC oiling. No load on the distributor gears to worry about.
Rob
