mpzmotorsports
hello everbody,, First off I am new to the site and this is my first post.. What I am working on is a 74 CJ 5 for my step dad. It has the stock 6 cylinder and a three speed.. Well he blew up the motor so he want me to convert it over to a V 8. The question I have is which is the best and easiest coversion to put a V8 into the CJ.. Here are the options I already have without buying a motor or tranny.. What I already have is a 350 chevy with a th 350 tranny.. I plan on using the stock transfer case.. The other option I can go with is a 360 out of an 82 wagoneer.. That will come with what i was told a 727 torqflite tranny.. I can get the 360 727 by trading the chevy stuff. I just want to know whats might be involved with both swaps before i commit. Any ideas? I am open to all opinions.. thanks Marty
mkzmomo
Go with amc's v8 easy swap. You should watch your rear d-shaft lenght its going to be really short with the auto tranny back there.
you will need a passenger side engine mount for the swap if you can get a cj 304 mount its the same
good luck
mpzmotorsports
If i use the 360 amc motor will it bolt up to the 3 speed bell housing? If It would I might just leave the stick in the jeep.. Any idea? Marty
mpzmotorsports wroteIf i use the 360 amc motor will it bolt up to the 3 speed bell housing? If It would I might just leave the stick in the jeep.. Any idea? Marty
It'll fit just fine. But you will need the P-side motor mount, and make sure you have a clean 3-row radiator.
mpzmotorsports
It sounds like the 360 swap is going to be alot easier, and probably cheaper... I am assuming I will also need to get a flywheel for the 360... Also who makes headers for the 360 into the jeep? If anyone knows of anything else i will need for sure let me know.. Also is there a place to get the motor mount new.. Thanks Marty
jinpdx
The 360 will bolt up to your T14 3 speed, but it wont last long if you have a heavy foot. The V8 CJs came with the T15 3 speed, which is alot stronger. Some people have good luck with the T14 and a V8, just don't be to hard on it. There are alot of T15s out there and they are cheap. I would find one to put in while the drivetrain is already apart
dan58
Go with the Edelbrock shorty headers.
mpzmotorsports
Well I don't know for sure if i am going to change the transmission or not.. The jeep isn't for me, my step dad is one of those guys that doesn't like to spend the money to do things right,, so I guess if he blows up his stock transmission then he will have to get a different one.. But we will see.. If it was up to me i would rather have a 4 speed over a 3 speed.. What model of 4 speed would I be needing if i decided to go that way.. Marty
Oldyeller
T-18 4 speed from a ford bolts up to the bell housing.
with the 360 everything should work out fine I have a warm 304 with a t150 and so far its holding up pretty well. If you swap trannies you will need different driveshafts. as far as the flywheel goes they are available but I would be sure that it is balanced properly as some of the cheap ones are pretty far off and make sure you run a good clutch cause cheap ones burn up pretty quick if you drive with the skinny pedal :lo1l: :lo1l:
jinpdx
The t150 is what replaced the t15, although it is not quite as strong as the t15, it is alot stronger than a t14
highlandercj-7
If you use the ORG trans (assuming the CJ had the 258 inline 6 with a 3 spd and a Dana 20 t case) It is a direct fit the bell is the same pattern. The fly wheels are scarce around here any way so I bought a new one. The stock waggy 360 won't hurt the 3 spd or the Dana 20, my Dana 20 is still the org t case and it's had a V-8 hitting it since it was new. Every one makes headers, I despise the fender well ones but to each there own. I'd run the stock manifolds and exit the duals out the back. IF you run headers get in the frame ones. 4wd Hardware has everything you will need. You will need to work out the motor mounts as V-8's are different. IDK about 75 and earlier but 76 up the right mount was the only different frame mount and then you need the block mounts. If you don't have a 3 row rad already you will want one. It's a perdy straight forward swap.
Welcome to Bulltear! :!:
If budget allows, I definitely recommend the M.O.R.E. ( www.mountainoffroad.com ) bombproof engine mounts. Do it once and never worry about it again.
