dustym wroteI put the rear ones in, but I couldnt remove the fronts. Would that cause only a couple not to pump oil?
Turn the motor over 90* and prime 90* prime till you go 360* back to TDC. Some of the lifter oil ports do not line up with the oil galie and will not pump up or let oil pass thru to the rockers had this happen when I pre primed my 360 after a rebuild. Then recheck oil level and I bet you will find it low.
Dave ----
