I have around 12:1 cr in my motor
my cam is a crower solid 292FDP 500/510 lift
246/250 duration at 050 lift
https://forum.bulltear.com/assets/migrated-images/fuzzcj7_3ca731a1.jpg
wanting to go 12s and lower I would look at this cam or a little bigger - elec fule pump and no smaler then 8 an hose or you can starve the motor on the top end
I would look at the torker then air gap intake
my air gaped torker
http://s22.photobucket.com/albums/b315/401cj7/air%20gapped%20torker%20intake/
how much street/ off road are you going to doing?? if more track I would go with a 950HP holley carb or a quick fule 950 one
tranny conveter depends how you are going to drive it - gears depends on what size tires you run
spray who needs it
my heads 6090 I just cleaned the intake runners up and ground up the bowels - exhaust clean the compleat port up never touched the chamber at all [/i]
