tufcj wroteThrow hubs on it without a part time kit in the Q-trac, and it won't move with the hubs unlocked, unless the emergency drive is activated. In it's normal mode, the q-track is like an open diff in the t-case. With hubs unlocked, the front axles and driveshaft will spin, but the Jeep won't move.
All other dimensions and specs of the front are the same, except for the full time drivers in the front, like stated above. 79 should be a "big brake" axle, with 1 1/8" thick rotors, and a caliper bracket that is NOT bolted to the knuckle (6 bolts to the spindle).
Good point, I was just thinking he was swapping in a QT front axle into a nonQT Jeep. :oops:
