JERSEYJOE
NEED A SET FOR MY PLOW TRUCK. IT'S A 5 BOLT HUB. LOOKING FOR WARN OR MILE MARKER, NOT STOCK ONES...
I don't know that I've ever seen aftermarket hubs for the 5 bolt flange. I have seen many grenade.
Your best bet may be to swap to the earlier 6 bolt ones. They were much stronger and I believe factory was Warn. They will bolt on to your spindles.
JERSEYJOE
I should have but I already assembled it with the 5 bolt hubs. I ordered Superwinch Premium hubs for the 5 bolt hub. Let's see how long they last. If they grenade I will swap out the hubs later.
By the way Bob I used the trans crossmemebr I had and just drilled the frame for 4 7/16 through bolts to hold it up. I have had the in frame threads strip out. The through bolts seem like they might be stronger. This truck is used for plowing 80% of the time and sees very little road time and a little mild off roading so it should be ok.
