crabshaver
Looking for someone that sells AMC 360 disributor soft gear!
Need is for HEI on a 4.2. Although someone told me they used a stock 4.2 distriutor gear.
4wd or jegs or summit i think all have the bronze gears for sale. why not just use the regular steel gears? If you use a gm 250 HEI dizzy then you need the amc v8 gear cause the shaft diameter is different than the 258 dizzy
crabshaver
My buddy told me he used his stock 258 gear on his HEI. Has anyone done that? I mean it almost makezs sense.
hugh
Only a 304 or 360 gear will fit the chev dizzy, if you like I can prob dig one up, I,ve done about 3 conversions so far.
crabshaver
I would really apreciate that!!!
:razz:
hugh
Found it, pm sent
crabshaver
Thanks alot! :sa:
hugh
deleted
hugh
deleted
