jeepsr4ever wroteProbly the best thing you could do right now is install a new oil pump gear kit and a midplate. The midplate will take care of the gouges in the bottom of the pump and the gears will give you tighter pump clearances. Its not that bad of a install usually takes a novice about 1/2 hr.
:-| Sounds like you're trying to sell some goods, the real question is, Are they really needed :idea: :mrgreen: lol, just teasing man... I couldn't resist :oops:
In My Opinion... First check the base plate, if there is any gouges in it, depending on the depth of the gouges you can lap the plate to a smooth true surface. If the gouges are deep you can bring it to a machine shop and they can mill it for a few bucks... or you can go to a junk yard and possibly pull one for a couple bucks... If the plate appears to be good look at the inner walls where the gears reside... IMO this is the critical area. If there are gouges on the inner walls then you're basically SOL... and that is probably the oiling issue, (providing that the rest of your oiling system is up to par, mainly the bearing tolerances etc). My experiences have shown that if there is gouges in the base plate the inner walls are gouged also... Like Jeepsr4ever said, you want tight tolerances/clearances for better oiling pressure...
Jeepsr4ever: You mentioned new gears for tighter tolerances... Is the O.D. of the gears "slightly" larger or what? Did you change the number of teeth? I know about the little "design" at the base of the teeth.. But, Curiosity is killing me... wait, or is that from the cheap beer that I had last night??? :-|
Anyway, on all of my "old" oiling gears the O.D. never changed and the "tooth wear" was so minimal that you could barely see it on gear tooth vernier... and that was probably an error on my part... one of my old 304's had 89,000+ miles on it and the pump was original with no signs of wear, (surprisingly)... The Mains were tired so I changed them and had the crank brushed up and at a warm idle the 304 had 15-17psi depending on the oil filter/oil used. (Then I ran her at 7000+ rpms a few times and chewed the mains)... My 401 runs about 14-17psi at warm idle... w/10w40... my lopey 360 sits around 18psi at warm idle and that's with 20w50 race oil... and a few oiling mods :?
