These axles were out of a 1980 scout. The front is turned to have correct caster for spring over. It also has had new brakes as of last summer and new u-joints as well. The front comes with new mile marker hubs and long stainless steel brake lines as well as U-bolts. The front is setup for psring over or spring under. The rear has good brakes on it yet and has all the brake lines including the rubber line (rubber line has a couple of cracks). This set is complete and ready to run and both are 4.10 and welded carriers. The gears are in pristine condition and were broke in right and the bearings and seals are all good. Asking $500 for the pair (ready to bolt in). Will ship anywhere on buyers dime.
what are they set up for? CJ YJ?
Scout so they would need the spring purches moved. We could move them here no problem.
