To do a single rocker you either need to have the bosses milled and tapped for the bigger thread and the small raised area in the middle of the head milled down for use with guideplates or you can buy a set of (expensive) roller rockers for bridged heads from Harland sharp. Or you could find a set of single rocker heads (70-73)
