Same applies to HEI Dizzy's.
Just the Mechanical Advance Recurve Kits are different part numbers
and the Vacuum Advance Cans are different part numbers.
I prefer the "stock" style off the shelf Vac Cans to the "pricey" Adjustable ones
available from Crane, Accel, MSD, etc.
On HEI's the Total Mechanical Advance is determined by the
Weights, Springs, and the Mech Adv Cam Plate supplied in the Kits.
On Points Type it's determined by a Pin, Slot, and a Bushing
that comes in the Kits and goes on the Pin to limit travel in the slot.
For the HEI, the Vacuum Can to get is:
Desireable "HotRod" Vacuum Advance Canister for GM HEI Distributors
AR15 - Stamped on Flange of ALL Brands
#1973508 - ACDelco
#DV1843 - Wells - AutoZone
#VC1843 - Echlin - Napa
#VC262 - Standard Motor Products - CarQuest
#DR347 - Niehoff - where ?
#V399 - Borg-Warner - Advanced AutoParts
Start Adv @ 3-5 inches of Vacuum
Fully Adv @ 9-11 inches of Vacuum
Total Adv = 7.5 deg Dizzy / 15 deg Crankshaft
"HotRod" Timing Advance Set-Up for HEI Dizzy:
14 deg Intial Advance set with NO Mechanical or Vacuum Adv at idle
24 deg Mechanical Adv all in by 2500-3000 RPM's
38 deg Sub-Total Initial and Full Mechanical Advance
15 deg Vacuum Advance
53 deg Absolute Full Total Potential Advance
... with Vac Adv Can attached to Manifold Vacuum
14 deg initial Advance
15 deg Vacuum Advance with Engine Vacuum at Idle above 11 inches
29 deg Total Advance at Idle with NO Mechanical Adv coming in at Idle
Be careful of Detonation.
Reduce Initial advance, or the rate and/or amount of mechanical if it pings.
A Dial-Back Timing Light is a "must have" to get it set up right.
:idea:
