I don't have a Jeep, but the MSD & stock Tach in my '69 AMX works
with MSD 6T white wire triggered and stock Delco dizzy with a UniLite Conversion.
Do you have the MSD Instructions ?
They talk about two different kinds of Tach, Current Triggered and Voltage Triggered.
Also is the MSD White Wire Triggered or Magnetic Connector Triggered ?
Only if using the MSD Magnetic Trigger and a Current Triggered Tach
then the MSD Tach Adaptor is needed
Current Triggered Tach - two wire cinnections at Tach -
from Positive Battery post to ignition switch to Tach to Coil Positive
Voltage Triggered Tach - three wire connections at Tach -
from Positive Battery post to ignition switch to Tach to Coil Negative.
Coil Positive wire is split off beween Ignition Switch and Tach.
Third wire on Tach is attached to ground.
