fast77amx
i rebuilt my 304 last spring it still has less than 2000 miles on it, when i go to start it the oil gauge reads 80 psi, at idle then when i start to move and barly give it gas to accelerate it goes to 90 psi the only time it drops below 80 is after its been running for an hour then it will sit right at 60 but never lower. i am wondering if somthing is wrong and should i be woried i already shreded one set of cam and dizzy gears. i bought the melling reabuild kit that came with my rebuild kit from summit.
Sounds like a stuck pressure relief valve. There's a large nut/plug on the back of the oil filter adapter, under that is a spring and plunger.
You need to make sure the plunger moves freely in the bore, and that it's facing the right direction. The point goes in first, away from the spring. They can varnish up and stick, brake cleaner works well to clean things, a little scrubbing on the plunger with a scotch-brite if it needs a little more clearance.
Over pressure can cause the dizzy gears to fail, they just weren't designed to carry that much sustained pressure. If you replace them, replace as a matched set, even if one gear looks good, There are at least 3 (maybe more) different "flavors" of gears, each with a different pitch.
dwg86
I was wondering the same thing. My 401 has 80 psi cold at startup. If I rev it it goes to 90-95 psi (cold). When its warm at idle 40-45. Driving/cruise about 60-65. If I stand on the skinny pedal when its hot it still goes to 80 psi (rev limiter set to 5800 rpm).
I am running Napa 15w40 diesel oil (suppossed to have 1500 zinc). and a napa gold oil filter.
Oh yeah, one more thing. When I start it up, it takes a while to build oil pressure?
(401 .040, 10.5:1 forged pistons, reed cam 228/332 dur@.050 512/518 lift 110 center, harland sharp roller rockers, 291C heads, milodon oil pan with dual pickup, airgap/750 eldebrock. about 500 miles on rebuild)
run thinner oil 10-30 or 10-40
fast77amx
just shatterd my second set of gears i bought a matched set of msd gears and in less than 200 miles same thing junk so yea im def gonna look at the plunger
WHOA what spring are you running.
fast77amx
the stock pressure one that came in my rebuild kit it was reddish brown in color
Plunger is stuck there because the stock spring shouldnt let the pressure exceed 65psi. Take that plunger out! :idea:
AMX69PHATTY
What Oil Pump Cover Filter Adapter is being used ? Stock ?
Asking since the Pressure Relief Plunger is in it.
If someone was to Hone the pressure relief plunger Bore
in the oil pump cover filter adapter
what should the finished inside diameter be ?
fast77amx
yea its the stock one
The stock spring shouldnt allow any more pressure than 65psi. You must have a worn oil filter adaptor.
kc eatman
look where your pump gears run, there's a small port that goes from the wall of the bore into the relief valve bore, if its plugged oil pres. will be very high!!
