Dusty
like she says dana 44 ARB air locker USED 30 spline
ARB air locker 4 series carrier so 3.92 and higher gear sets. worked fine when removed. bought it with the intention of running it in my cj. this is the model with the slightly thicker copper line. comes with the collar & copper line, spacer, ARB locker the brass compression fittings and the brass fitting that thread s through the housing. pretty straight forward. it had new o-rings installed a tthe collar while it was out, and since has never been installed.
first $560 gets it shipped to the lower 48
located santa rosa CA
mike4089
is that numerically higher gears???? or is it 3.92 and lower numerically
Dusty
gear split is 3.73 on dana 44's
so it uses 3.92, 4.10, 4.27, 4.56 ect
