I need a Dana 44 front cover (the thick one not the tin rear cover). Working on an experiment with moving the fill hole up because I have the pinion tilted so far up. Let me know what you want for one.
Ibby
Check out junkyards for late 70's/early 80's Fords with high pinion 44's. The covers are the thicker type and the fill plugs are already raised up on them. I have a pair on my CJ due to the pinion angles also. If you can't find any let me know. I'm home on leave in August and I'm sure I can wrangle some up for you.
PavementPounder
I may have a thick one on the shelf. I'll take a look.
