JERSEYJOE Anyone know of a hydraulic clutch conversion for a Jeep with an AMC V8? I am using a Wrangler tub so there is provision for the clutch master cylinder already. Can I use the standard YJ clutch master cylinder and buy the slave cylinder, bolt it on and go???????
FuzzFace2 JERSEYJOE wroteHey I got it figured out. Thanks everyone for the help.You not going to let the rest of us know how??? It could help some down the road you know. Dave ----
JERSEYJOE But of course I will. The problem is that the factory master cylinder has a wierd hose connection that is held in with a roll pin. Advance adapters makes a fitting that allows you to use a standard hydraulic hose . This allows you to use a slave cylinder from an 85 CJ with 151 4 cylinder... Should go easy. will update as I finish it..
