I am thinking that my current cam sucks and it has to go. I would like advice what might be a better fit for my needs. I spend most of my time rock crawling but the 4-5 times a year that I use the motors power is when I get disapointed after losing uphill drag races at the sand dunes against my friends who are simulary (sp) equiped.
Ok on with my specs:
1986 CJ7
401 bored 40 over (1972 year i believe)
Sealed power forged pistons part # L2380F40 not sure of compression ratio
58cc heads with SS valves it looks like somebody did a little porting but have no info on it or if it was done professionally
Air gap intake
770 holly truck avenger
mallory unilight dist
6AL MSD ignition box
Eldebrock shorty headers
Summit 8601 cam
Roller rockers 1.6
19" flex fan
2500 stall convertor
4:10 axle gears
727 trans with low gear kit (this changes axle ratio to 4:56 in 1st & 2nd gear)
Std Dana 300 transfer case
2 1/2" dual exhaust with Moroso racing mufflers
125 HP NOS kit
When I had this motor in my old jeep that had a T18 stick in it the motor was alot faster. I have made alot of changes (intake, convertor, carb & MSD) but it still is not happy as it was. With the stick it would run 5500-5800 rpm but with the auto it gets 4000-4500 rpm. I change from the stock converto to the 2500 stall to get the cam into its power band. Lets hear your thoughts!
Some pics too:
http://pic16.picturetrail.com/VOL683/2960043/5984984/311696338.jpg
http://pic16.picturetrail.com/VOL683/2960043/5984984/311696344.jpg
Thx
Dave
