Thanks,
Any solutions to the problem in your memory bank? Seems like a big gap to try and clamp and weld - at least 3 inches!!!
I'll get to it eventially, so it's not critical to get it running, but working right is the long term goal. Pix would be a bonus of course.
Appreciate the help. :t:
Also, the link in your sig doesn't work #-o
mrtazwrench wroteThat's a common problem on these hoods, either poped up in the wind like noted above, or it happens when the hinges get stiff and are forced open. Some of them may have been glued I have not been paying attention to the ones I'm normally under. I have a 63 Jtruck here that I'm storring for someone and that one has more bracing than any of the newer ones I've seen not sure if that helps this issue or not. If everything else is ok on that hood maybe try to work them back in place and find something to glue them with, I don't think welding is an option as it would dammage/distort the outter skin, which could be the reason they are not attached as you stated this one still looks fine from the outside, had they been attached solid it may have just pulled the outter skin with it when this happened.
