Just don't get suckered into using a double pulley with two different diameter pulleys on it like we did. We thought the smaller diameter pulley would make the steering pump spin faster at the lower speeds often encountered off-roading. That is true, but the downside is the smaller diameter pulley gives much less belt contact, and we couldn't stop the belt from slipping. We had to replace it with one with equal size pulleys.
Note: I've tried and tried to get the above pic to show. I don't know why it won't. I even pasted it into one of my posts over on JU to see if it would work, and it showed up just fine.
