DolceCJ
I just ordered a matched set. Any breakin procedure to use after installing these?
Going in an AMC360, Comp 268H CAM, HEI
No real break in. Coat both gears with an assembly lube so they don't start up dry. Make sure if you've replaced the timing set that the oil passage in the cam gear is clear, so oil can get to the dizzy gear.
