mike4089
the stock bolts from the stock oil filter plate wont be re-useable with the oil filter relocator will they?? if not then what size and length do i need to get
1 5/8" (1/4-20) bolts or 1 3/4" length
mike4089
and when i buy a new gears for the pump at the store it comes with a gasket...that gasket is fine to use correct???
the gasket should be fine. you can measure your pump clearances and determine which gasket will be the best fit.
