I have run that oil for awhile in my 401 but now I've switched to a 10w 40 blend. Alittle lighter oil, got oil pressure alttle quicker at start up.
As far as synthetic oil, I am completely sold on them. I've seen idle pressures increase with synthetic, more stable and higher hot idle pressures.
I have a 3.1L Chevy with over 250,000 miles(before I got hit in the side) that I changed twice a year. Once in the spring and once in the fall. averaged 15,000 to 22,000 a year. This motor still ran like a top, had power and was still quite.
Someday I want to take that motor apart to look at the bearings and rings. :idea:
Now my 401, which is driven like I stole it :lo1l: sees its oil changed once a year maybe. But I don't drive that one much at 10mpg Prem gas 🙁: :smile: I also have a bigger sump and dual filters WITH those filter mag things on each. Total of around 9qts then I add 2 bottles of crane cam break-in lube. A little over kill probably...but its cheaper than to rebuild again do to an oil issue. :t:
That being said I think unless you are really pushing the power or want to run extended drain(with reasonable filter only change) synthic isn't worth the price. Dino oil is a hundred times better than it was 15 years ago. I also believe the 3000 mile oil change for cars is to often, but no one is really pushing it very hard.
