65postgs
I just received my new bulltear distributor gears today. I do have a question about the installation though. Do I need to put some assembly lube on them or just install and prime the system with oil?
Thanks in advance
Both. Cover both gears with assembly lube, then prime the system before starting. Always better to over lube than run new gears dry.
65postgs
Thank you for your input. I was assuming this but wanted to be sure.
