happyhoppy wroteThanks - feel better about that. I usually hit pretty close to what the machine shop gets.
I have the heads off and measuring the bore with the pistons at bottom of the stroke.
Kinda new at this but learning fast but I have another question.
Do I need to take the pistons out to measure the piston to bore clearance or is there a way to measure with them in the bore accurately?
Another quick question - the AMC service manual said to bore if the bore exceeds .005. Is this realistic?
Not going to see any high rpms or many high performance add ons.
This is a super well maintained engine with 55000 miles and I'm wondering how far I want to go with this rebuild.
Read a little more and found answer to piston to bore clearance - dumb question after seeing how easy it is.
What made you tear into the motor? Honestly, if all looks good and measures out to be fine, button her back up! But, before doing so purchase a new timing set. :t: look into and through the lifter valley and inspect the lobes of the cam makes sure the top of the lobe isn't rounded or on it's way to being rounded... it should look similar to an egg (Sort of).
