randyrussell13
Just wondering what any of you guys are using for electric fuel pumps, and what size pump would be needed fro a 360.
Edelbrock 600 cfm carb, Edelbrock intake (non egr), and cam. MSD ignition, billet dist. Headman headers
For a carb'd motor, you want a pump with 7 PSI max, and you'll want to have a regulator near the carb. The best pumps are the gerotor type, stay away from the diaphragm type. You want to mount the pump as close to the tank as possible, they are designed to push fuel, not pull it up.
I used a generic one I bought at a local parts store for years before going to an in-tank type when I went EFI.
FuzzFace2
As Tufcj said :lo1l:
On my high 12 sec drag car I am running a Holley Blue pump out back on the frame rail pushing to the reg up front.
Its a little noisy for street if that is what you are going to use it for but it is good to 12 flat at the track they say.
Dave ----
fuzz401
randyrussell13
Very nice!
keparrott
I've had good luck over the years with the Carter CRT-P4070 electric fuel pump on my 360. Max 6psi.
