The down side to the indy cover is that the oil doesn't go back into the engine in the stock location. I had the oil pressure sending hole on the block opened up and feed the oil back into the engine there.
Oil pressure is taken now from a hole that I had to drill and tapped into the Indy cover! You need to get a remote filter housing and alot of AN fittings and lines to get the Indy cover to work.
If I did it again, I would run a single line from the oil pan I think.
After that you will never have another oil pressure problem again. 40lbs at idle to 100+psi if you dare at anything above idle!
The cover is thicker and made of a better alum. than stock. The pump is rebuildable. The only other thing I've noticed is the oil pressure takes a few seconds to build on start-up. Synthetic oil helps...think its a combo of all the lines the oil runs through and the oil pump gears.
If you are going to run a AMC v8 and keep it for a rebuild or 2, its a good invenstment.
