ironman_gq wrotemaybe when you put the new gears in the gasket didnt compress properly and as it ran the gasket decided to compress and the tolerances in the pump tightened up. see if any of the adapter bolts are looser than they were.
You know you might be on to something. Just went to check and was able to turn all bolts an additionnal 4-6 degrees. Not much but a little.
