]1979 Jeep CJ5 😢
Orange w/black top
http://rides.webshots.com/photo/2502369810056642908FFIbkC
250 I6 Chevrolet
SM 465 tranny dana 20 t/case
Wide track dana 20 and 30 4.56 gear locked f/r
33" mud terrain tires on 8 x15 wheel
cage tied into frame.
Bestop supertop and a new extra softop skin
and a lot more.....
Winch and battery not included in sale.
Jeep was driving by Karen on weekends with a lot of fun and very little to no breakage. The SM 465/dana 20 tcase combined with the 4.56 gear ratio comes up to 60.72 crawl ratio. Very good little crawler. Extremely manueverable with drag link tie rod end flip kit removing all bump steer. Suspension is simple, 4" superlift using stock shackle arrangement. Rear axle has been stitch welded at the tubes to prevent axle tube spinning and has a differential guard installed. Axles are widetrack which add great stability to a CJ5, especially off camber. Front axle dana 30 has all new seals throughout. Both axles have lockers installed, lock right lunch box and have never had a problem.
The SM 465 was overhauled last spring and shifts very smooth and positive. A master bearing overhaul kit installed with several internal drive gears due to wear and tear over the years prior to being installed into the Jeep. Driveshafts front very heavy duty using heavier gauge tubing ( can't remember) but were built by Standard Parts. Rear is a Cherokee front drive shaft cut down to the CJ. The shaft has a CV style joint to remove all vibrations that the CJ5 can create especially lifted 4".
The only real down flaw is the fuel delivery which is a single barrel carburetor.
Garage kept
Check out all the pics at:
http://community.webshots.com/user/timporter1959
Please feel free to give me some feedback, I want to get a fair price but really, let me know what you think.....
thanks.. tim
[b]4,000.00[/b]
call 757- 877-4758
Located in Newport News Virginia
