4.0L H.O. head with the water holes spray welded for use on a 232-258 block. Has new valve guides and Mopar Direct Connection stainless valves and springs for up to .530 lift. The valve pockets were ported and a 3 single valve job performed. The valves are currently set for a .500 lift cam but can be changed for up to .530 with these springs.
I originally bought this from Clearwater cylinder heads (the ebay guys) and went to install the stainless valves only to discover that the guides were installed at all different heights and two were in upside down. That's why Clifford gets $1000 for the same heads and Clearwater only charges $425 I guess. I had everything wrong with the assembly of this head CORRECTED.
I'm going 401 now so I won't be using this head.
$500 plus the ride. I have about $800 in this head. Every part in them is NEW.
