DolceCJ On Bulltear the HEI is listed two ways, (1) without matched gear set, (1) with the matched gear set at a higher cost of course. With a Comp 268H in my AMC360 would I need this? :?
ironman_gq the cam makes no difference in the cam and dizzy gear. anytime one of the gears is changed they should both be changed as a set to make sure they will mesh properly and not wear out prematurely.
