dave44
can i use a pressure plate from an amc 4.2 on a amc 304 ? im sure the answer is no.but im not sure.
Wrench Man
If the bolt pattern is the same, why not? I've put V8 clutches on my 258's before.
BREK
Even if it bolts up I would suspect that it won't have enough pressure to hold the torque of the mighty 304?
i did the opposite with a v8 pressure plate on the 258. they should be the same part and if its a rebuild they probably dont distinguish between the two engines. should work perfectly
76-cj7
ya know....the more i think about it....in an ol CJ-7 i got w/o a title it had a 360 with an TF999....it was shot so i swaped in a t-4 from my buddies jeep and actually used his flywheel and used my warrenty on a previous clutch and used one from the I-6.....i dont think there is a difference in the clutches but the thing that seems to baffle me now is how a I-6 flywheel didn't vibrate like a sum bitch :-| #-o i think i need to stop drinkin :razz: #-o
Now that you guys bring it up... I swapped the 6 for a 360 in the J-10 and ordered the same 6 cyl clutch for the truck (T-176 not T-177 trans.. (Don't ask I was young and stupid, Moved mounts forward 4" instead of finding the longer input shaft t-177).. and have had no trouble for 10 years or so..
