mrtazwrench
I put a flowkooler water pump on the 360 in my 87 J20 last winter I had to use both gaskets that came with it for impeller clearance, :roll: well now I need to tear down to replace the timing cover gasket leaking coolant. #-o I got no reply from flowkooler when I asked how to order new gaskets, :(: has anyone here got new gaskets from them before or have another place to get some that will work. :t:
mrtazwrench
well just went and checked my E-mail, finally got a reply after 2-3 weeks with a phone # to call. :roll: If anyone has helpfull info you can still post it up :t:
BREK
Just go to napa and get yourself 2-3 of their gaskets, should work fine. I put a flowkooler on my amx this spring when rebuilding the engine and I had to use 3 gaskets to get the impeller to clear the cover.
