Rhinolined360 wroteMy power steering pressure line broke on the metal portion of the hose where it screw in to the pump, it screws off the hose, so anyways I'm in the process of using a brake like to replace it. I know you guys get really technical when answering questions, I need this to last till Wednesday- will it last 4 days like this or does it build up to much pressure. Can this be a permanent solution, if it does leak from all this rigging?
Couple things here -
First how do you get a little brake line to fit the connection? My sup & rtn PS hoses are like 5/8"???
Second, I had brake lines made that support 9K PSI so it should handle the 1-1.5K pressure on the pump pressure side, but ...
Third, if it is the small diameter line - your going to have steering problems just do to the lack of volumn which means your NOT gunna steer worth a crap. And that is a bad thing #-o
Why not just replace the hose and fittings?
