mike4089
who has done it? where did you mount it? and if you have pictures of the finished install that would be great
What are you mounting it in?
In my CJ, I made a simple "L" bracket, and mounted my dual remote filters to the bottom of the battery box. I have a 1 piece fiberglass front, so I can't mount anything to the inner fenders.
mike4089
it is going in a cj...i was thinking about putting it under the battery box but i didnt know if that would be to far away....also do i need to add a little more oil to the motor when adding this...i will also be adding the oil cooler from bulltear
Dual filters will need an extra quart when you change both filters (6 quarts with a factory pan), maybe a splash more for the cooler. I don't think it would even hold 1/2 quart.
