OK, got this one sorted out. After beating myself up, I took the T-case all the way back down to parade rest, pulled the gear clusters apart, and checked all the shims etc...
Then I put the b!tch back together after everything checked SAT. Since the instructions were LAME on how to install the shifting rods I did a net search and found NOTHING for the Teralow kit, but found some GOOD info from some guy that did a LOMAX kit.
See the lower left shift rail ... ?
Of all things I had installed the rear shift rod in upside down and the cut out for the larger gear was keeping it from falling in place :oops:
Thinking about it, the case is assembled upside down, but the DWGs are all right side up. #-o
Oh well, it's back together and has the first coat of primer on it =D>
