jeepsr4ever wroteDid you grind the case...you do know the case needs to be ground for the large gear.
Yup, but not that much, just the notch they said to carve out.
Got it figured out though ...
After beating myself up, I took the T-case all the way back down to parade rest, pulled the gear clusters apart, and checked all the shims etc...
Then I put the danged thing back together after everything checked SAT. Since the instructions were LAME on how to install the shifting rods I did a net search and found NOTHING for the Teralow kit, but found some GOOD info from some guy that did a LOMAX kit.
See the lower left shift rail ... ?
Of all things I had installed the rear shift rod upside down (180* out) and the cut out for the larger gear was keeping it from falling in place :oops:
Thinking about it, the case is assembled upside down, but the DWGs are all right side up. 111!!! (ok so that's a lame excuse, but that's my story and I'm sticking to it! :wink: )
Oh well, it's back together and has the first coat of primer on it :t:
