Wrench Man wrotefifesjeep wroteHelicoils SUCK!!!! Eventually they twist out etc...
You're putting them in WRONG!, they are THE! thing for fixing threads!
If you use the CORRECT drill bit and tap the hole properly they are STRONGER than the original threads!, I've installed more than a hundred at the machine shop with EXCELLENT results!
=D> It isn't hard doing helicoils, especially when the kit comes with everything needed. Install tool, drill and tap... 111!!! There just not good for torquing on... There good for snugging things up... Especially the smaller bolts...
You obviously never used Kingserts (Key Locking Inserts)... Here's a test for you, Put a Helicoil in an open hole and put a 1/4"-20tpi grade 5 bolt in it and make sure the threads stop 1/4" from the hex... Run it down and once the threads run-out torque on it... What happens???? Now do that with the helicoil in the closed hole... Check the results and write it down... Now use the Kingserts.... :mrgreen: I gaurantee if it's a 1/4"-20tpi grade 5 bolt and you wrench on it with the kingserts installed you'll twist the grade 5 in-half :idea:
Helicoils are good for minor "stuff" I've worked in a few Machine shops, Civilian and Military... Helicoils go out the door for the "Non-important" jobs. If grinding the threads out to a minimal of 22.5* (per side) and weld filling then machining isn't needed we use Kingserts... The reason most peopl don't use them is ONE... they don't know about them and never worked with them first hand or TWO they're too expensive and don't want to spend the $$$ for the quality product... I used to be all about Helicoils until I used the Kingserts... I actually tested them at a Convention out in LA back in the day... From there I was hooked... every-place I go I make sure I have Kingserts... Give it a shot, you'll see what I'm talking about.
